[NA] PB Hard Top (prise dégivrage+plafonnier)
FJP78
Re: PB Hard Top
Message par FJP78 » 01 janv. 2016 20:37
En faisant une petite recherche, j'ai trouvé ce post, je ne sais pas si ça correspond à ton problème:
- viewtopic.php?f=17&t=24745&hilit=DEGIVRAGE+ARRIERE
ou bien ;
http://www.ilmotorsport.de/shop/article ... ad4c5baed8
ou se passer du dégivrage arrière .............pas très pratique
Bon courage
MX5 NCRC 1.8l Brillant Black Elégance Cuir année 2007
Je suis responsable de ce que je dis, pas de ce que tu comprends…
orazur29
Re: PB Hard Top
Message par orazur29 » 01 janv. 2016 21:46
Bonsoir, j'ai également fait une petite recherche:
Q) How are the various Mazda tops different?
All Mazda hard tops are based on the same design. All are made of "sheet molding compound" (SMC) which is kind of like fiberglass. They have a large wraparound glass window, with defroster elements after 1994. The top is held on by 4 latches (two at the windshield header and two behind the doors) and 2 cleats that slip over "Frankenstein bolts" on the rear deck. The top weighs between 40lbs and 50lbs, depending on model year. My 2003 Mazda hardtop (which has both the defroster and headliner) weighs 50.5lbs.
Mazda changed the hard top design 4 times (so far):
1989-1991 - Original
1992-1997 - Defroster and Headliner - This top has a defroster built into the rear window, along with a wiring pigtail to connect it to the car's electrical system. This top also adds some more insulation to the inside of the top, reducing noise and heat loss.
1999-early 2003 - Pigtail - This top has a different plug style for the defroster pigtail. The L-shaped brackets to hold down the soft top are also longer in the NB top than in the NA top.
Late 2003-2004 - Latches - This top has redesigned latches to match those on the 2003+ cars. See this TSB for VINs. If you want to use this top on an earlier car, you must replace the strikers or they will be damaged and the top may not stay latched! It also has the new defroster pigtail plug and longer L-brackets like the '99.
Il semble que les premiers hard top n'avaient pas le dégivrage ce qui peut laisser penser que les NA de 1991 ne sont pas précablées.
Comme l'indique FJP78, il te faut installer le faisceau électrique adéquat mais à mon avis, c'est du boulot en perspective...
Bon courage si tu te lances car autant j'aime faire de la mécanique auto que l'électricité auto et moi, ça fait deux !
_______________________
MX 5 rouge de 2001 - 1,6L - 110 CV - Adhérent n°772
Re: PB Hard Top
Message par Bugatti112 » 01 janv. 2016 23:05
Bonsoir à tous et mes meilleurs vœux pour cette année 2016.
Effectivement pas de dégivrage pour les 1ere génération de NA donc normal que tu ne trouves pas de prise pour cette fonction.
Après l'ajout de cette fonction n'est pas bien compliqué à réaliser.
A peluche
Nico
